does anyone experiment hangup problem with N80, Route66 and Royaltek RBT-2001?
Sometimes, during navigation, the application hangs and the display light turns first dim and then off. After about 20/30 seconds it resumes itself.
Firmware version of N80 is 4.0623.0.42
Any idea? :con?
MrAnderson wrote:Hi,does anyone experiment hangup problem with N80, Route66 and Royaltek RBT-2001?
Any idea? :con?
What version of Route66 are you using?
I believe you need at least v7.3.468 for N80 compatibility.
Also, the GB maps shipped with R66 around July contained errors which would crash the phone. Sorry, I don't know what version of map fixed the errors.
Dez
