What is the difference between using the following codes:
Vanilla EURO 1 code - 0539101
EMEA region EURO 1 code - 0527009
What is the difference here, and which code should I use? Excuse my ignorance 😉
I used the 0527009 code with my o2 N73- worked just fine!
Joeybuk wrote:I used the 0527009 code with my o2 N73- worked just fine!
Thanks, I will probably use this code.
Can anyone explain what EMEA and Vanilla mean?
:icon14:
Vanilla means generic.
EMEA means Europe, Middle East, Asia.
Not sure what the difference is in terms of what's in each firmware build though.
