N70 + Musicplayer + Headset problem?
12 replies · 3,224 views · Started 28 November 2006
Hi!
I got Nokia N70.
I also have Headset HS-61 with Music adapter AD-46.
I cant adjust volym with the HS-61 whick i think is very bad, is it possible?
I use the MusicPlayer who was installed in N70 and when i listen to music and my phone
ring, the music stops to play (of course) but when i stop talking the music dosent start to play
again, it has stopped which i think is so bad.
Can i use another MusicPlayer r am i still got the same problem?
Thanx!
HS-61, could be hardware... or not compatible with N70, check if is the case on Nokia Site.
About Music Player on N70, seems SW. Do you have the last firmware version installed? Check with NSU if is the case.
How do u see what firmware u have?
How do u update your firmware?
When u update firmware, does it format everything on the phone?
Is there another and better musicplayer to my N70?
pontusfs wrote:How do u see what firmware u have?
1. *#0000# on standby screen
2. Via Nokia software updater (NSU) tool with a data cable
3. Yes.
4. OggPlayer is the best free player.
Where can i download ogg player?
Will it work with ogg player so my music continue to play after a call?
Thanx, i have installed OGG and WInAmp, but i cant get it to work. I serach for musicfiles (MP3) and it looks like he find them but when its finished it ends OGG, and when i try to open it again i cant find my mps files? Whats wrong?
I got firmware v 2.0539.1.2, whats the latest firmware?
Is any use for me to upgrade?
Sure, do the upgrade. NSU - Nokia Software Updater tool. Make the download of that, from www.nokia.co.uk, N70 support pages. After install, follow the instructions and do the upgrade yourself.
Wirelessly posted (NokiaN70-1/5.0616.2.0.3 Series60/2.8 Profile/MIDP-2.0 Configuration/CLDC-1.1)
how i adjust my equilazer
pontusfs wrote:Thanx, i have installed OGG and WInAmp, but i cant get it to work. I serach for musicfiles (MP3) and it looks like he find them but when its finished it ends OGG, and when i try to open it again i cant find my mps files? Whats wrong?
I'm using 2.0536.0.2 so this is not the problem.
Regarding OggPlayer: the files are sorted in multiple ways, but you can find them unsorted in (files) - that's how this appears in the player.
