3250 sis installation
14 replies · 6,972 views · Started 29 November 2006
i tried to install smart movie.sis file on my 3250 and it displays
"installation of smart movie.sis not supported" i need to knowwat file format it accepts
Wirelessly posted (MOT-C975/80.2F.36I MIB/2.2.1 Profile/MIDP-2.0 Configuration/CLDC-1.1)
kayz wrote:i tried to install smart movie.sis file on my 3250 and it displays
agmpa
agmpa
agmpa
agmpa wrote:Wirelessly posted (MOT-C975/80.2F.36I MIB/2.2.1 Profile/MIDP-2.0 Configuration/CLDC-1.1)
agmpa
how
how
i tried installing some sis files using the pc suite.but it keeps on saying dat the installation of the file is not supported.
I dont know wat else to do. I cant install anything on it.
Are you using SW for S60v3? The old software don�t work on this new S60 phones.
Wirelessly posted (Nokia6230i/2.0 (03.50) Profile/MIDP-2.0 Configuration/CLDC-1.1)
I think you installed file s60 2nd edition OS 8,8.1 (eg N70,6680 7610 etc) your 3250 is s60 3rd edition OS 9.1 (eg N91,3250,N73) thist applications can be seen some sites ok
This site have a software section. Search on that section, the programs you need or want.
Wirelessly posted (Nokia3250/2.0 (3.18) SymbianOS/9.1 Series60/3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1)
search smartmovie on my symbian wap site.i installed it and it is working properly for 2 days still today on my 3250
3250 is s60 3rd edition phone the software to be installed has to be compatible with s60 3rd edition phones the smart movie you are installing seems to be of s60 2nd edition check out funmaza.com then mobile mania-mobile softwares- 3rd edition softwares page 12
