Probably Stupid General Question About Unlocking and Factory Reset
3 replies · 5,758 views · Started 29 November 2006
If a handset (6630) has been unlocked by the network, then you apply a factory reset with *#7370#, does that re-apply the network lock?
Thanks. I thought that was probably the case but I thought I had better check. I bought a used "unlocked" 6630 on ebay, factory reset it, put my sim card in and got "sim card not valid". I'm now getting a refund and buying a new, sim-free E50.
