application manager n themes
6 replies · 13,118 views · Started 30 November 2006
Overall, I am pretty happy with my N73. However, I am now having problems with my application manager and my themes. I downloaded quite a number of themes and installed them in my phone. As far as I know, the installed themes are supposed to be shown in the application manager. But now, I am not able to view ALL my installed themes in my app manager. I want to uninstall some themes but do not know how to, besides pressing the [c] button or uninstalling it from the app manager, and neither works now. I can't delete it frm the app manager because the particuar theme is not shown there. Is there any other way to delete/uninstall those themes?
You can transfer the data from your old mob. to the N73 including your contacts , inbox , gallery , ...... , and also remove the installed themes from N73 memory card by the following procedures:
1- For theme removal from memory card : when you connect the USB cable to the N73 it asks you about the connection type (normally we select "PC suite"😉, Select "Mass Transfer" where your PC will recognize your N73 as a card reader, so you can see your memory card and all the hidden files and folders.
There you can find the installed themes in "Private" folder and you can delete theme manually.
2- For contact and data transfer there is an application installed on the phone by Nokia (default from the manufacturer) named "Transfer" in the applications folder, run this program and it will contact any other nokia phone (through Blue tooth or Infrared) and pull all the data from the other phone after asking for permission.
these procedures i have tested by myself and they are perfect.
hey.. i did it.. n yea, the themes r no longer there but in the app manager, those themes r still being labeled as 'installed' when i view the log.. is it supposed to be like that?
Hello, I have noticed that many people have problems with themes installation for Nokia N73, I've experienced the same problems but I managed to uninstall those themes by deleting them from the memory card using my phone as "Mass Storage" device, but the themes remain on the log in App.Manager and if you try to reinstall them you get the message "unable to install file".I was wondering is there a way to clear the log so that the theme can be reinstalled? I have installed a file browser (Y-Browser) but I cannot manage to find the logfile...any suggestions???
Thanks!
Has anyone been able to solve this log file issue?? How do you read it / delete things from it?
I had a fabulous theme and changed it to something else to show my cousin then went to put it back and it had vanished. I went to re-install it and had no joy. I went looking for the files in mass storage mode to make sure it was uninstalled and tried again... still no joy - it won't re-install.
I've installed Y-Browser to attempt to find the logs but contrary to what it reckons, you don't seem to see all the files on the phone.
I'm seriously disappointed at this and if anyone has any suggestions I'd be VERY grateful.
Cheers,
Duv
try search the files thru mass storage mode.. Do a search inside the private folder and see if it helps..
I have same problem but i cudnt find themes files in private folder...all i can see is these folders(100012a5,102072c3) and some files inside 100012a5 like DBS_101FE031_mcv7 n DBS_101FE031_mcv5.Do i have any other option to delete installed themes in n73?
