N80 not working anymore
12 replies · 3,534 views · Started 30 November 2006
hello ...i updated my N80 to RM-92 IE APAC PR v15.00 SW4.0632.0.38 ....i got the message that ..the update...was ...successfull ..and after that i tryed to turn on the phone...i get the nokia logo...and..then i get a bip..and my phone is not starting anymore...can you please tell me what can i do?..to fix that😞(....thx in return:frown:
juato4 wrote:have you charged the phone previus upgrade??
yes i had the version v4....... from september...
but now when i try to start it..it will not start i just get the nokia image...and then after few seconds i get a BIp...and nothing
or you could retry flashing the phone.
or dead phone flashing
DaniN80 wrote:yes i had the version v4....... from september...
This happened to me yesterday. Try the hard reset operation...
1. Power off the phone
2. Press the following keys at the same time:- GREEN, 3, *
3. Power on the phone (still holding the three keys listed above)
4. After about 20 seconds your phone should power up normally.
If the above doesn't work, you may need to take your handset to an NCC for repair.
Dez
DaniN80 wrote:😊 thx....man😉....it worked..thx a milion😉....
No probs. If you ever pass thru Scottish Borders area you owe me a pint!
:icon14:
Indeed I do.... I have more problem now...maybe you can help me with this olso........... when i try to reinstall the TomTom 6 and route 66 i get this message ...phone date may certifiate may not be valid ,is expired..or phone date settings may not be correct😡
yes.. this is a option... you must to activate the option " all software".. because the certificated is active.
bye.
go to app manager press the left softkey for options and the 1st setting make sure its "all"
