I just cant for the life of me get any applications installed on my phone. Whenever i transfer a file via Pc Suite, it says that "Installation of abc file.sis is not supported". It is getting very frustrating. Cant get anything installed whatsoever. Have only managed to get a couple of apps installed. why is this happening? Please help!
Totally unable to install sis applications. help!
dr_razazain wrote:Cant get anything installed whatsoever.
dr_razazain wrote:Have only managed to get a couple of apps installed.make your mind up?
I expect your problem is you are not installing compatible applications (eg if they are s60v2 not s60v3). if they are compatible then you need to changes the settings in app manager to install all files not signed only.
hey man, i guess u messed up with the settings.... Try go to application manager and open settings and check the options their
