Powerful timing tool for your workgroup
Netwell Group Calendar for Lotus Notes 4.6 or newer is a great tool for your Lotus Notes teams to connect several Notes calendars to one automatically by server updated view. You can manage appointments and reservations of your team simply at one view. Every team member can personally choose whether to show or hide a calendar entry from the group view. No design changes are needed to Notes mail databases.
Easy to use
Netwell Group Calendar is a Lotus Notes database which you can copy as many times you need. Licensing is server basis, so single team calendar can contain an unlimited number of persons and every user can be simultaneously joined to one or more team calendar. Netwell Group Calendar looks and works just like your own calendar, so it needs no education.
Web browsers can also access Netwell Group Calendar, so you can easily check your team's appointments wherever you are connected to Internet. Just install the product and you will get the benefits of group scheduling at once.
User�s comment
"We were tasked by management to come up with an easy to use group calendar that would show at a glance what managers were out of the office. They also wanted to be able to click on an entry to get more detail as to where a person was at and how they could be reached. After testing several products (including what is included with Notes Release 5) we decided to purchase the Netwell Group Calendar as the one that best met our needs. When one of our top managers called Netwell "elegantly simple" I knew we made the right choice."
--- John Herron, U.S. Fish and Wildlife Service, Department of Interior, USA
Easy to install
Just copy one nsf-file to your Domino server's data-directory, open the database with the id, which has enough rights to run scheduled agents on your server. Enter a database title, agent server, how many days you want to keep old entries and persons and groups, whose calendars you are going to join. Now the group calendar will update itself as adjusted. You can change the settings any time by going to Group Calendar Setup (in Notes actions).
New version 3.5 now available !!!
( only for Domino R5 )
The new version has a lot of new settings and features as follows:
Multilingual end-user interface in English, German, Swedish or Finnish
Support for Nokia 9210 Communicator mobile phone and other PDAs
Multiserver support (you can connect your calendar from multiple mail servers by just replicating the calendar database). Remote access to all servers from same view
Fully customizable lineformats for Notes, Web and PDA use
Better memory handling
Lower CPU usage
List views by person-, room-, location-, category- and resource :P
