Slide Show applicationn for N93; bugging!
0 replies · 4,177 views · Started 01 December 2006
I have a 2g card now and copped over 50 photos to the card to have them run as as a slide show using the slide show application....
problem 1; when opening the slide show from the Gallery applications menu and the images and video, the slide show does not pick up all the images on there only like 20 or so
problem 2: of a lesser concern, but having set the slide show as a shortcut key (the button next to the 'settings' button) the slide show does not run at all
Anybody experiencing the same issues using slide show?
I am an engineer and that slide show function is extremely useful for me, running site photographs to audience linking with a tv display...
The more I get acquinted with the N93 the buggier it gets unfortunately....
I had 3 smartphones now, and I guess with smartphones generally, there so many posibilities and applications and combinations of applications to use, its impossible for the manufacturer to completely screentest all firmware thoroughly.....
Still I am without a fully working slide show and there so no good software out there that provides a fix for this
