Question on the E50: Does it support Goodlink push email?
On the Nokia web site for the E50 it says:
Support for leading push email clients, such as Nokia's Intellisync Wireless Email and BlackBerry Connect, gives easy access to emails
While for the E61 it says:
Choice of email solutions - supports �push� email (Intellisync Wireless Email, BlackBerry Connect, Good Mobile Messaging, Seven Always-On Mail, Visto email technology)*
On one hand for the E50 is suggests others are supported, where as the E61 explicitly lists those supported.
So, is it supported on E50 or not?
Rick
From my point of view, it is a "Goodlink-Problem."
It seams, they do not whant to support the E50.
Same thing on the E70. :icon13:
It should work, but I may not find the SW.
die 52
die 52 wrote:From my point of view, it is a "Goodlink-Problem." It seams, they do not whant to support the E50.
die 52
You might think that - untill you realise that Nokia itself shuns the E50 and does not support the E50 in on many of its own software too. For example, try and see if you can install Nokia Lifeblog on the E50 - you cant.
So why on earth should we blame Goodlink. For all we know, Nokia themselves may have told those guys not to bother with the E50 - or just plain blocked them.
