Sipgate and the N80 IE firmware
4 replies · 4,813 views · Started 02 December 2006
Ok I've got my N80 successfully upgraded to the IE 4.0632.0.38 firmware and I've been playing around a bit with the SIP Internet telephony settings. I'm trying to get it to connect to the Sipgate network (which apparently works just fine with the E60 and E61) but so far I've had no luck. I notice that the public user name is always prefixed with "sip:" which isn't suggested on the Sipgate site but there doesn't seem to be a way around this.
Anyone else tried Sipgate with the N80IE yet?
The 'sip:' prefixing is standard behaviour on the nokia devices. This behaviour is seen on all of the ones I have configured even my N80ie.
I can't help you with why it doesnt register with Sipgate, my N80ie is registered fine with the asterisk servers that Gradwell use.
elaverick wrote:Ok I've got my N80 successfully upgraded to the IE 4.0632.0.38 firmware and I've been playing around a bit with the SIP Internet telephony settings. I'm trying to get it to connect to the Sipgate network (which apparently works just fine with the E60 and E61) but so far I've had no luck. I notice that the public user name is always prefixed with "sip:" which isn't suggested on the Sipgate site but there doesn't seem to be a way around this.
Can I have hoe for Upgrade N80 to N80 ie.Thanks in advance.
vijushi wrote:Can I have hoe for Upgrade N80 to N80 ie.Thanks in advance.
Can you please stop making multiple posts...this is very ANNOYING...
Search for a thread where the first post is what you need and then make ONE post in that thread and you will get an answer..
All the answers you need have already been posted many time...you just need to spend some of your time reading through the posts and learning about what it is you need to do..
Hmm I seem to be struggling making it work with sipgate...
I followed the setup guide, but when I go to Internet Tel and do connect to service it tries... then comes back with "unable to connect the connection network"
The wlan works, the necessary ports are forwarded from the router to the phone which is on a fixed IP. The xlite client works absolutely fine on my pc & laptop so I just changed the forwarding rule in the router to the mobile. Any ideas?? Is there any log info available for the SIP registration?
