Messages from 6600 to N70
2 replies · 1,853 views · Started 03 December 2006
I was just wondering whether an N70 and a 6600 uses the same memory card, and whether or not we can transfer messages save on my folders of 600 to N 0?
The 6600 uses full size MMC memory cards, whereas the N70 uses the Reduced Size (RS) dual voltage MMC, so you won't be able to use your 6600 memory card in the N70. You could use the N70 memory card with an adapter in the 6600, so it may be possible to save the texts on to the card that way.
The Data Transfer/Data Mover app that comes on the N70 will be able to pull contact, calendar & gallery data across from your 6600 via bluetooth. It won't, however, transfer emails, multimedia messages, or text messages. To do this will require a file manager application, like the freeware FExplorer, to locate & transfer the text document data.
Failing that, just forward the texts across.
HTH 😊
Rob.
