Message Sent to Outbox
4 replies · 3,383 views · Started 14 December 2002
I was just wondering, is this a common problem with the 9210? After about 100 or so messages sent, I always have to re-install my .dat files just to avoid having this problem, it seems like restoring the .dat files is just a temporary remedey, because the problem acts up again after a certain number of messages sent. Does anyone know how to completely get rid of this problem???---Message sent to Outbox??? id have to resend it manually by opening the outbox and pressing "send now" ....help pls! I have a version 3.62 btw, no problems except for that
Do you have Celesta MyStyle or Extended Messaging installed, if so do you have the latest versions. I think (I may be wrong) that was an issue with very early releases of Extended Messaging. That said I've never known that problem except when I am out of cell coverage.
nope, i don't have those programs...do they come with the CD rom? DO i really need those? pls enlighten me, thank you 😃
Nope you don't need those apps, they are just useful if you want to view and send picture messages or operator logos to people. They are the only apps I can guess would effect messaging.
