Hi all,
Please try this on a P990 and explain it to me
Open the Flip and do the following:
Open Task Manager and close all running applications
Then go to Main Menu >>> Media Player >>> Video >>> Demo Tour
Then press on the Back icon going back 4 times
Now go back to the menu and you will notice your phone is very fast
Anybody can explain this to me :con?
This is silly, there is nothing to do with RAM
I've searched and here what I found
There are two reasons for that:
1. Opening the media player will turn on the video acceleration and this will consume the battery faster of course
2. Transition effects are disabeled and this option will be available in the next update as I heared
hell yea this does work it did work as fast as video ipod yea probably the video accelaration becomes enabled, i wonder if there'a way to make it enable no matter what
Works good. Nice trick, thanks! Too bad if it consumes batter life quickly. Looks like if you close the media player it goes back to slow. Hopefully they will update to eliminate transition effects.
