Sync problemes
1 replies · 1,190 views · Started 03 December 2006
Hi I am facing the following problem.
I am not able to synchronize notes, contacts, calender of the nokia 6600 I have with my PDA (HP iPAQ 2790b) via Blue tooth.
I introduced the phone as a paired device and I was able to send pics from the phone to the PDA, but when I went from the phone menu to the connections folder and then to sync there was a failure in synchronizing.
Can you please help me and if possible teach me how to set my PDA to connect directly to my yahoo mail (what are the server address and the domain)
Thank you.
You can't do direct device-to-device synchronization between the phone and a PocketPC PDA, unless you find synchronization software for both devices that knows how to talk to each other.
You can use PC Suite for the 6600 to synchronize it with a PC (and Outlook there), and then Microsoft ActiveSync to synchronize the iPAQ with the same PC.
