Can anyone tell me where i can get this part of the nokia instalation from as the only way you can get it is if you wipe your phone is to install all and i want it as a seperate component like everything else on the disk so i can only install what i want and not the lot then delete what i dont want! Regards.
Profile instalation
do u want to install or make a new profile? or do u want to delete or edit the profile apps?
lemme know maybe i can tinker with my phone and give you an answer
I want the profile instalation file as i like to only install what i want instead of the install all option on the 9210 c.d! The profile instalation is the only one missing as everyhting else can be installed seperatly. Regards....
Here you go..
Cant get straight link to that file even i have it in puplic folder.. wonder why..
btw, it's v2.0 and taken from sales pack CD..
JeP
Cheers, Thats a great help as it is not on my instalation disk.Thanks for taking the time in putting it on the forum!!!
