Nokia N73 Software problem.
3 replies · 7,822 views · Started 05 December 2006
Hi All.
I copied a software unto my memory card, now when i put the memory card back into the phone, the software installs itself, but i receive an error saying that untrusted software found on memory card, install from application manager. Any ideas.
Did you try to do what the message says you should do? If not, why not? If you did, what happened?
