GPS Receiver for N73
8 replies · 4,764 views · Started 06 December 2006
Am looking for a GPS receiver for my n73, and recomendations. I have Tomtom 6 on the way so needs to work with that.
Regards
Jim
Nokia LD-3W, because is a SirF Star III, 20 channels, and use the same battery from Nokia line and same chargers, car and house. I use LD-1W, inferior, without any problem. But that market have, maybe, thousands of choice devices...
Yes, at least one more, but I don�t remenber the name... is more or less a no name brand.
I've been using a an iBlue GPS unit, it ships with mains and car chargers (USB type). There aren't any major problems with "no name" GPS units, as they all use one of two basic chipset types (ie. the SiRf and whatever mine uses).
Battery life is supposed to be quite good, up to 30 hours continuous.
clonmult wrote:I've been using a an iBlue GPS unit, it ships with mains and car chargers (USB type). There aren't any major problems with "no name" GPS units, as they all use one of two basic chipset types (ie. the SiRf and whatever mine uses).
From where can i download a GPS receiver software for my Nokia N73
I don�t know any one free. Only pay ones. See on software section of this site.
Divakar_p13 wrote:From where can i download a GPS receiver software for my Nokia N73
GPS isn't software and you can't download it. If you want to use Satellite Navigation with your Nokia, you will need to buy a hardware device called a GPS receiver like this one....
http://cgi.ebay.co.uk/BT77-BLUETOOTH-GPS-RECEIVER-FOR-NOKIA-N70-N73-N80-6680_W0QQitemZ300056977244QQihZ020QQcategoryZ4668QQrdZ1QQcmdZViewItem
This is the one I have and it has worked very well with my 6600, 6680 and N73. The battery life on this particular model is exceptional with the device lasting almost an entire weeks use before needing a charge.
Once you have this device and once you have bought suitable software like TomTom, Route 66 or Naviman, you're good to go 😊
