I tried 3 time all times everyting work fine untill last stage of USB Flashing end up with below mention error when I hit
flashing -> sw update>>enter product code 0543922 >> start
ERROR is :
Changing phone's operation mode failed
do you want to retry?
HRESULT 0x80043005(-2147209211)
CMtcFFN:Setcurrentmode, transition not allowed;mtcfn=0x80043005
Only changes I see from standard procedure . during phonix installtion i have block internet access to application called "Root" .and removing sim and Memory card when i reboot my cell i ask for nothing (use without SIM etc).
Do i have to select any profile during flashing? i tried general and offline both did not work. any suggestion?.
thanks in advance.
vijushi wrote:I tried 3 time all times everyting work fine untill last stage of USB Flashing end up with below mention error when I hitflashing -> sw update>>enter product code 0543922 >> start
ERROR is :
thanks in advance.
vijushi
I seem to remember somebody saying to try flashing with the sim in, this may help
what version firmware do you currently have in your phone now ??
what is the mode displayed on phoenix window. Is it "RF Inactive" or "Local" or "Normal". Before flashing if its in "RF Inactive" change the mode to "Normal" and then start the flashing. See if it works....
I tried it with "Normal mode" and it workd.....
~Cheers
yes ,U have to choose normal mode and after select the product code u want..
it worked for me now i got N80IE ..;with phoenix..
