help.. can't clear my logs
8 replies · 2,810 views · Started 14 December 2002
how come i can't clear my logs???
i allready cleared it and for some reason it comes back when i open the logs..
i can't clear it.... help... it makes my logs so... s.l.o.w........, when i try to acess it................ :x :cry: :-? :evil:
Hey,
Maybe try to find the log files via a file manager and clear them.
i am sure that someone here in the forum know were r they.
Good luck,
Gideon
Ok, logs are fine, but do you really go through them? I would suggest to set your phone not to do logging.
all ready did that
i set it to "no logs" then the logs are cleared ryt??
then i look into my logs, its cleared...
but when i exit and enter the logs again its still there...
i can't clear my logs, it keeps coming back everytime i reopen it...
Would you tell us a little bit of a background? So that we would know what have you been up to. 😃. So that we would know how to solve your problem....Hopefully.
