What Bluetooth Dongle Do You Use?
5 replies · 1,625 views · Started 14 December 2002
It has to work with your N7650, Anything you had to do to get it working [This is 7650>PC] In the aid to stop people asking what will and wot wont work!
And anylinks if possible
When u say BT Dongle, do u mean the hardware or the BT software???
Billionton works just fine, after i changed the BT software.
Since most hardwares (the actual adapters) are about the same, its the software that seems to be the issue in this instance.
I'm uses MSI Transceiving Key. Works fine on my PC.
Not very stable on a slow machine example: PII or below.
