i want to ask U 1 question, so, for example i have 1 friends number and i have 1 enemy 😊 i wanna create a block list of enemy contacts... when the enemy calles the N7650 automaticaly disconnect it and will report me about this call,time of cALL etc.
so do u have any ideas? if you have really workin idea or apps please send me a private message, cause of speed to recieve the answer +))))
lol naivri.
im almost 100% positive that there isn't any such app, but im completely certain that it would be possible.
lets call our beloved helper...
DOMI 😃 !!! we got a mission for you :P
Well, you can set the phone not to ring when someone from a specific usergroup calls, can't you?
As Makkara says, this is the best and faster solution. I use this too! I have created a caller group especially for some "undesirable" people :roll: 😉 8) .
But it would be very nice to be able to divert immediately these people to another number (voice mailbox or other wrong number 😉 ) and have a log of their calls (evil, isn't it?) 😃
yeah, but aren't you going to get charged for forwarding? Costly if it does.
[quote="igogo"]i want to ask U 1 question, so, for example i have 1 friends number and i have 1 enemy 😊 i wanna create a block list of enemy contacts... when the enemy calles the N7650 automaticaly disconnect it and will report me about this call,time of cALL etc.
so do u have any ideas? if you have really workin idea or apps please send me a private message, cause of speed to recieve the answer +))))[/quote]
yup. this should be nice. 😃
No need 3rd party appl. It's already in your phone.
Step 1.
Create a group all "block list" in your contact list menu.
Add those you want in this group
Step 2.
Goto your profile menu, goto the Slient group. Select Personalise, scroll down till you hit the "Alert for". Click on it and Uncheck All click, check the "block list" group to it.
You should not have any more ringing tone or alert from the pple inside this block list ringing your phone. If they called you, your phone will not beep. They will able to have ringing tone from their side but not yours.
Hope this help 😉
[quote="Edgedale"]No need 3rd party appl. It's already in your phone.
Step 1.
Step 2.
Hope this help 😉
so do u have any ideas? if you have really workin idea or apps please send me a private message, cause of speed to recieve the answer +))))[/quote][/quote]
edgedale, i dont think it works that way. if you do the steps you mentioned you get the result the other way around! remember the option is ALERT FOR, so if you check the group of BLOCK LIST, then you will only be alerted for calls by people from the BLOCK LIST and from not from anybody else. please double check. 😃
any additional feedback on this? i want to make sure what i said was accurate for the sake of the thread starter. :-?
I dunno what answer your all looking for - best i can say is move all enemies to a profile and set no tone for it - Or a single plip or sumat - I know my t300 had an option for blocking calls - get one of them 😉 [7650, t300 and the t68i are the best phones around. No argument]
I think you are right...it's the other way around. So, it should be that there is another group... "OTHERS" as well. Then, the Alert For should uncheck the "ALL" then check all others except for the "BLOCK LIST". 😉 😃
Nooooooooooooooooo! You're not my fatheeeeeeeeerrrrrrrrrr.
[quote="Zipper"]I dunno what answer your all looking for - best i can say is move all enemies to a profile and set no tone for it - Or a single plip or sumat - I know my t300 had an option for blocking calls - get one of them 😉 [7650, t300 and the t68i are the best phones around. No argument][/quote]
Move enemies to a group - Do new profile, in profile select alert for that profile - Or get a silent ringtone and assign it to the enemies
[quote="Zipper"][quote="Zipper"]I dunno what answer your all looking for - best i can say is move all enemies to a profile and set no tone for it - Or a single plip or sumat - I know my t300 had an option for blocking calls - get one of them 😉 [7650, t300 and the t68i are the best phones around. No argument][/quote]
Move enemies to a group - Do new profile, in profile select alert for that profile - Or get a silent ringtone and assign it to the enemies[/quote]
oh my god! that is the exact wrong way of doing it!!!! if you do that then you will get alets only from "enemies" because you chose the option ALERT FOR!!!!!
arrrgghhhh!!!!! enough of this! 😃
p.s. it's just funny, you quoted your own post.... 😃
[quote="Makkara"]Well, you can set the phone not to ring when someone from a specific usergroup calls, can't you?[/quote]
Yes you can.. its very simple.. but kgb will kill you! :evil: 😊
