What A good Idea!!!!
6 replies · 2,275 views · Started 14 December 2002
My previous SE had an 'always on' option for Infrared! this would be Excellent for the 7650, anysuch device that does this?
when the phone has established a connection with nokia pc suite it doesnt disconnect until you tell it to.
edit: LOL! I love your sig.
hrm. sorry, i kinda misunderstood whta you said but i get it now... yeah that feature would be pretty cool 😊
[quote="GhostDog"]I dont see the use of it,why would you need an always on infrared function?[/quote]
yup. it'll even drain your battery. :-?
Yes it'll drain the battery, How about "In demand On Feature"? So that whenever someone is connecting through IR, then this setting will automatically turn on the IR???
[quote="kobe24"]Yes it'll drain the battery, How about "In demand On Feature"? So that whenever someone is connecting through IR, then this setting will automatically turn on the IR???[/quote]
Becuase I'm pretty sure that means 'always on,' you can't recieve bits and not send a confirmation 😞
