Hi folks,
Is there a way of using animated gifs as a background?
Hi folks,
Welcome to the Forum
You can use Aniviewer which is a free software.
Please use the search tool before u post new topics as most would already have been answered.
Yes,but the gif animation will only loop once.You'll need an app to loop the animation infinitely.
-EDIT-
I was wrong about the app name and sanjay2402 beat me to it 😉
you can use e-profiles pro from psiloc :P
If you mean wallpaper or screensaver then answer is: no, you cannot use animated gifs there.
[quote="simeonbubblegum"]If you mean wallpaper or screensaver then answer is: no, you cannot use animated gifs there.[/quote]
Yes you can. with extended profiles pro you can have animated wallpapers
and with PsiLoc's screensaver you can have animated screensavers.
All about gifs!: :P
In English: You can use gifs in Screen saver (they loop forever)
edit: you can have them loop by using as wallpaper (using e profiles pro) (being away from this forum for 3 days results in alot of catching up to do!)
And you can view gifs (looping forever) by using animviewer, and seleq (the latest version) 😃
[quote="😊"]All about gifs!: :P
And you can view gifs (looping forever) by using animviewer, and seleq (the latest version) 😃[/quote]
true...
about eProfiles, i know that they have an option to animate background, but i've tried it several times with different gifs but havent gotten any to work. 8)
