N80 and tomtom v6
3 replies · 2,388 views · Started 08 December 2006
Hi
I have installed tomtom v6 and it works to a fashion, but i seem to keep loosing the bluetooth connection from the phone.
I say from the phone because a m8 tried my holox bt-321 bluetooth gps unit with his pda and it worked fine.
I tried it on a few jurneys and on a 10 mile journey i might get 5 miles of instructions, it then looses the connection, then comes back on after about 2 mins etc, because it worked on a m8s pda i can only presume its the bluetooth on my phone loosing it somehow.
any ideas anyone?
badgerdid wrote:Hi
any ideas anyone?
You should read the other threads concerning bluetooth in this forum and you will get your answer 😊..
badgerdid wrote:Hi
any ideas anyone?
Upgrade your N80 Firmware to V4.xxxx - as per the previous responder, the information is fully discussed in other threads, just do a search and read up on what's required.
Agree with Dez_borders, Mine work with the V 4.0623.0.41 26-07-2006 RM-92 (58.01) linked to a bt-338 receiver.
