Hi there,
I just been to a nokia service centre to upgrade my firmware, however the guy updated to the version
V 3.0617.0.6
03-05-2006
RM-92
Nokia N80 (33.01)
I believe this was the version I already had.
I've been reading a lot of posts talking about versions 4.0 up.
Can someone tell me if I'm running the right version
Thanks in advance.
kormisr wrote:Hi there,I just been to a nokia service centre to upgrade my firmware, however the guy updated to the version
V 3.0617.0.6
03-05-2006
RM-92
Nokia N80 (33.01)
Thanks in advance.
there is an updated version to your firmware, but it may depend on your location and what network you are on as to whether you have the latest version for your particular phone..
heres a website i find useful for checking lastest nokia firmware.
http://hunajatehdas.net/nokia/firmware/index_en.php
Thanks Guys,
The website for checking the firmware is great, it realy helps.
I'll be going back to the Nokia service centre and ask the guys there to try again, as acording to the website I supouse to be using the version:
V 4.0623.0.42
20-09-2006
RM-92
I shall post a reply to confirm this tomorrow, thanks for the info
u can use the official nokia updater program that supports the n80, its pretty straight forward, you'll need the usb cable
http://www.nokia.co.uk/A4226014
Thanks Wolverine, I'll try that when I get home and will go to service centre anyway.
I'll post a reply again with the results, hopefuly it will help on a few issues I'm having with my phone, including phone loosing power when ringing.
I'll let you know
Regards
