Hello.
Do I have to type my pre shared key every time? (It's not WEP)
What is the solution for that?
Thanks.
Hello.
Thanks.
no it is automatically stored,
under connection tab within settings, go to access points and under securty select wpa/wpa2, u then have another tab for wlan security settings, u can enter your pass phrase there
it is stored and does not need entering everytime u connect to the net via wifi
