Nokia 7650 Problems Help
1 replies · 1,375 views · Started 15 December 2002
I was just wondering if you guys could strain the sliding trails which open the N7650 keypad. I just have some thought that the sliding would eventually loose after about one year of use. Please give some opinion!!!
It's just wear and tear of the phone (same with any other product) but it will increase noticebly with even the smallest falls that can happen on your 7650, meantioned before, you can take it to the NSC and ask them to pull it together, they could sure make it slide smoothely again!
And another thing, you get used to it after, my 7650 used to be kind of loose, now i don't feel it at all! 😮 (but that's because it fell 3 times, (hard falls!!)) On the other hand,my class mates's 7650 slide is perfect, no loosing no nothing. 😃
