Greetings to all
i have bought nokia n70 middle east version before two months, then i made update to its software, before that i took a backup of the phone, while downloading the update software from nokia website i found that in the middle east region there is no new software is available but it is available in the europe region. i downloaded it from the region. after aplying the new software to the phone i noticed that the phone is not supporting the arabic version therefore i cannot restore my datas from the back up file because the datas are in arabic and the phone now does not support this language.
my question is how can i get back to my original setting of the factory that can support arabic language?
i have tried the formating way but i found that the update happened to the rom file. so what is the solution now? can any one help
Try new upgrade, with NSU tool. On Auto mode, it gonna install the software from the phone region. It should be enough.
nj7 wrote:Try new upgrade, with NSU tool. On Auto mode, it gonna install the software from the phone region. It should be enough.
thanks for ur quick respond,
can u plz send me the link?
www.nokia.co.uk - support pages - software - Nokia Software Updater tool. Install it and follow the instructions. Is an easy process.
nj7 wrote:www.nokia.co.uk - support pages - software - Nokia Software Updater tool. Install it and follow the instructions. Is an easy process.
thanks dear and this what i did first time
i think u didnt understand what i want now?
before my phone supported arabic language i.e: i was able to send and recive sms in arabic also make the interface of the moblie in arabic but now after i update it, this feature disappeared, now i can only recieve in arabic but cannot send in arabic niether the interface can be in arabic. how can i make it support arabic writing also make the interface in arabic?
You cannot. Arabic is not included i european version. Only solution to that problem is to reflash the phone with one for that region. Or going to NSS to add arabic language.
