it wont load my powerpoint presentation up, it shows progress bar and loads, then does nothing, what versions of powerpoint is it compatible with? i tried with 2003, no luck ;/
anybody use quickoffice with powerpoint presentation?
Not an answer to your question cbcharlie but a question along the same lines. I just tried to open a word doc in Quick Office. I sent the file to the documents folder & Quick Office can see it but I get a blank screen when I open it. Do I need to change the file extension of the doc ?
Cheers
