Is it possible to mod the m600i so that the hardware button (the one labeled "@) can be a shortcut to the volume level that you could adjust with the scroll wheel.
It's a little annoying having to enter menus or use the stylus to adjust the volume. If you should just shortcut to the volume screen that would be great!
