Help in some files
5 replies · 1,359 views · Started 15 December 2002
where can i get the 9210 Initialisation and PCMail Initialisation .sis files? I know its part of the All_data_9210_device.sis in Nokia's website, but does any of you have these 2 files individually?
I have been experiencing problems in installing these 2 files coz under Control Panel= Install/Remove, both files are only partially installed. Would I experience any problems if I just let it be?
Thanks.
Thanks Dazler for the tip. But unfortunately 9210 initialisation is not on the site.
As you can see at the attached file, Nokia 9210 Initialisation is only partially installed. I tried installing/ formatting the device several times but I keep on getting an error at the later end of the installation.
Could I just leave it at is? My new formatted phone works fine...SO FAR.
Also....after formating my device and usinf a new MMC, Icon manager stopped working. Whenever I tried accessing it, it says...NOTE: NOT FOUND.
I tried downloading a new .sis file from your website, I tried installing it a couple of times, I tried downloading it from 9210 (which says file corrupted)...but no luck. Help on this too.
Do you have OPL installed? 😉
Well if it works fine, just try it for a while? The phrase "never touch a working system" comes to mind 😊
Oh....hehe. 😮ops: Forgot to install that when I reformatted my unit. Thanks, dude. 😃
