NOK 6600 problems :)
5 replies · 3,345 views · Started 10 December 2006
Greetings
I'm new here
So, I have a nokia 6600 wich started to act strange couple of days ago.
My camera stoped working, I have been receiving "temporary overload" message.
Some parts of my phone stopped working, like bluetooth, infrared.
Most applications wouldn't work. I would often receive messages like
App. closed mce, App. closed gs etc etc...
So I've started googling and I've done following
A soft reset with *# etc
A soft format also with *# etc
A 3-button hard format
Only once (in about 10 times) after format phone worked again. Everything was ok. 30 minutes later, same story.
I've pulled out my memory card out (in case there is a virus on it) formated it, but nothing changes.
Is there help for me or ???
If you have tried the soft and hard formats on the phone and wiped and formatted your memory card and you are still having problems, it would suggest a hardware fault and that would probably make it uneconomical to repair 😞
Have you tried with another SIM card ?
ur phone is infected by virus.
Hi there here is the solution.
1.first of all, format the phone Nokia 6600(*,3,green)
2.Secondly,Restore the phone to the original setting.(*#7370#)
3.Thirdly,restore the phone memory backup in memory card(mmc) to phone memory.
4 push menu button ,go to memory, push option button restore to phone memory(yes"😉
5.reboot ur phone.
6.For safety,always backup ur phone memory in memory card for further troubleshotting when ur phone is infected by virus.
is there a way to remove the virus.
2 days ago I've dona 3 button format, then *#7780# and everything worked without problems for 2 entire days. this night i've tried to receive a file via bluetooth from my friend and the phone went crazy again. what to do ?? i love this phone 😞
I had a virus in my n-gage called doomed caused me alot of greif that was pretty nasty....I found a manual removal on a site called umuglobal in the encyclopedia they have, you may have some luck there?🙄 hope this is of some help to you. If not I'm sure someone out there will know somewhere else to try.
I have nokia 6600 and I am getting the same problem and i have tried all methods of formatting but it does'nt works. What should i do now can anyone please help me. I dont want to lose this phone.
peshta1 wrote:Greetings
I'm new here
