Problems installing latest firmware
4 replies · 2,812 views · Started 10 December 2006
I have an N73 and realise that i equire the latest firmware upgarde after reboot during incoming calls. I downloaded and intalled Nokia Software Updater but cannot seem to coonect phone while this program runs. The phone connects using the PC Suite supplied with the N73 and I can transfer files with no problems, but as soon as the updater program is run the N73 automatically disconnects from the USB port, but when the updater program is terminated it automatically re connects???
VERY CONFUSED....PLEASE HELP?????:con? :con?
If I undestand, is like that. The phone, when connected on PCSuite, disconnects it self with NSU tool. Is that?
Try update your PC suite to lastest version of 6.82, yet? That might help, since it come with phone update section preinstalled.
I have Nokia Suite 6.80.21 already but cant seem to find the update section for the latest firmware??
You don't need a Nokia Suite.. I installed a 3.0638.0.0.30 ME firmware By just installing connectivity cable driver, NSS and NSU.. All you need is to select Suite, when you try to connect your phone to your usb
