real player playlist of rm files
6 replies · 19,183 views · Started 10 December 2006
im unable 2 make playlist of .rm files in real player so every time i hav 2 go back and play next song. is der anyway i can make .rm files playlist? also it is not possible 2 so anything while playing a song in real player(it pauses) can i minimize it? or else is der any other software 2 so these things? i tried mobile theatre but it also has same problem
also if i try 2 play .mp4 file only audio plays and it shows a msg dat it can only partially play the file. is der any software 2 play .mp4 files? the real player in n72 plays dis
You can create a playlist for RealOne player by adding several entrys to the ram-file. This works for local playback also.
Here's an example:
suppose you have two RM files (audio1.rm & audio2.rm) present in "Audios" Directory of MMC then just create a file in notepad
with following entries:
file:///e:/Audios/audio1.rm
file:///e:/Audios/audio2.rm
Save the file as a ram-file (filename.ram) and send it to your phone.
Now when u play this .ram file to ur RealPlayer the songs will be played automatically one by one 😊
Note:
1. obviously this .RAM file is a TEXT file.
2. Use E:/ for MMC & C:/ for Phone Memory
gapata wrote:Hi,
Here's an example:
Note:
hi bro gapata,
it is working perfectly on my N70.. thanks a ton.. i was looking for .rm playlist maker or a player which can make .rm playlist since last three months.. i have got it now and i have many .rm files on my N70..
Thanks once again..
c ya
nitinule
First, Thanks for showing us this great way of making a playlist for rm files, I have been searching for this for 8-9 months with no positive resutls, finally I came across ur post. Thanks again.
Although it's working fine on my N70, but i have a small problem, when I play my amr or mp3 files, it's giving a diff display for playlist, like pause, play, previous next button etc etc. but when I play rm files, it's opening in different interface, usually when we play video files in real player it uses that interface and with a small message that ' can't play the file, will play partially' it starts the audio. I tried to change the extension of rm files to ram, ra, rmm, amr and wav within phone itself, it's working fine but with same results.
What's the fun in having a playlist when u can't scroll in the playlist. Is there a way where in we can get the interface of mp3 paylyst or amr playlist when we play rm playlist.
By the by I am using real producer plus 10 to convert my mp3 to rm files with a setting as no video.
Thanks in advance.
Regards.
AKK.
Hi gapata,
Thanks a million for the solution.
I tried it with the default real player in Nokia 3230, it works beautifully.
Keep up the good work.
gapata wrote:Hi,
Here's an example:
Note:
Hi Gapata,
pla tell me that the .ram file create on PC or In Phone
