My Infrared Port Is Used By Another Application..help Please!!
1 replies · 3,127 views · Started 10 December 2006
[FONT="Arial Black"][/FONT]
I M TRYING TO CONNECT MY NOKIA 6600 TO MY WINXP SP2 VIA INFRARED CONNECTION..WHENEVER IM TRYING TO CHECK THE INFRARED CHECK BOX I GET THIS ERROR MSG..
"IT S NOT POSSIBBLE TO USE THIS PORT AS ITS USED BY ANOTHER APPLICATION"
HOW TO REACH THE PORTS SETTING IN MY MACHINE SO TO SET A DIFFERENT PORT FOR IR CONNECTIONS TO STOP THIS CONFLICT??!!!!!!!
PLEAAAAAAAAAAAAASE...HELP...
I TRIED INSTALLING AND UNISTALLING MY PC SUITE SEVERAL TIMES ....DIDN'T WORK...
ANY SUGGESTIONS FOR A TORTURED MOM??!!!!😡 😡 😡😡 😡
Hey man calm down...
maybe u need 2 format the phone (without the memory card)
but anyway don't use the IR port it's too slow if ur using it to recieve files or send them I suggest that u use the bluetooth it's faster & by using the pc sute to transfer files u'll get better & ur phone...
