someone help with this please?
can the n80 be upgraded to n80 IE
what is the diff of n80 to n80iE? what are the main differences and what are the advantages of n80iE over the n80?
jakeywakey wrote:what is the diff of n80 to n80iE? what are the main differences and what are the advantages of n80iE over the n80?
Heres some info.
http://www.nokiausa.com/phones/N80ie
Phone not available in UK at the moment
As for upgrading the firmware - use the search facility in this forum for some excellent articles by members.
jakeywakey wrote:someone help with this please?
I guess you were unable to read the thread titled "N80 -N80i firmware upgrade guide" just a few down from the top???
To answer your question, yes - you can upgrade your N80 to the N80ie. Check the thread posted above. I used the instructions this morning to successfully upgrade my N80 and it worked perfectly.
One note, though - be sure to follow the instructions carefully. Hope your success is as good as mine - it's upgraded and working like a champ. 😉
Maybe he means for a nokia centre to upgrade it officially?
James761 wrote:Maybe he means for a nokia centre to upgrade it officially?
It's unlikely any Nokia Care Centre would upgrade N80 to N80IE FW, but someone please prove me wrong. 🙄
