SMS Fake Sender ID
2 replies · 19,184 views · Started 12 December 2006
Some time ago i have used a little application called smsXtender that could send SMS�s with Fake Sender ID.. We could choose the number (even letters) we want.. When the other person receives the message it appears the message came from that number (or letters).
Unfortunelly, that program uses a GPRS connection with their servers and from one moment to another it went offline 😡
From that moment, i am searching a application like that but without success.. I�ve found some webpages that promisses to do the same, but when i send the message it appears like it was sent by a strange number, not the number i choosed.. Some webpages work with some networks, but not anothers.. Vodafone in Portugal is one example that doesn�t work.. It receives the message with a strange number, not the one i choosed
Does anyone knows a app ou webpage that could send SMS with Fake ID? I want it for use in Portugal, but even you don�t know if it works in Portugal, give me your suggestion, then i try it 😊
Sorry my bad english
Erm I can't think of a legal reason why you would need this type of application so I doubt many people will help you. Sorry 😞
Just Sharring Fake SMS
If you have number from :
Faroe Islands, Finland, Denmark, Greenland, Iceland, Norway, Sweden and UK
Try Register and Get 30 Fake SMS, You can register with 1 number more account, check, What Your number after in this check Username and pass, if your number not use, You can register with same number. Check Account Aktif or Not Aktif after 3 or 4 day Register to www.sendega.com
If you wont send Fake SMS use in this link : http://sms-smart.co.cc
