Help! Java and SIS
8 replies · 2,844 views · Started 15 December 2002
Where I can find application files for the 7650 that AREN'T trial, demo or purchase?! I used to use www.midlet.org for my Siemens SL45i, but none of those programs are really for the 7650. My main question, and application that I have and most of you have, is that file mananger program? Where can I find it? Is anyone able to post the link or something? Much appreciated! Thanks!
PS What is an .sis file?
Register here, and you can have many free apps and games from here.
after registration you can see attachments.
Or try from here:
http://www.allaboutsymbian.com/software/
I've registered and stuff, but I'm a relative newbie. Where are all the apps and stuff located? *blush*
Try this thread for FileExplorer:
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=5392
and by the way, there are no w***z in this forum. 😃
I've just downloaded it ... doesn't work though :/ Keeps saying system error and all I see are C: D: Z: - with no files though. Anything on here actually FREE to play with now instead of paying $10 - $20?
It works fine on my phone :-?
free games:
rockOban
yahtzee
and get those game zip packages from game section
apps:
Coctail
bemused
try the search!
Got it going! When I selected 'properties' on a root drive (C, D or Z) it gave me the error only. I *think* that's normal though. Anyway, is there anyway an idiot like myself could destroy the phone by deletign or touching some important file?!
Most likely yes 😃 be carefull, dont delete anything if you dont know what it is.
But you should get it back to working condition with hard reset... ...maybe.
Domi should release a new version really soon with new options and stuff.
