Live messenger on 3
2 replies · 1,891 views · Started 12 December 2006
Is it possible - it still says that the handset is not supported.
Has anyone managed to install the official version offered by 3?
I assume it uses some sort of proxy to connect as I can't get agile messenger to conmect to msn apart from over WiFi?
I wish people would punctuate a question with a ? or something, I got all excited (I still use my old 6630 which in many ways I kinda prefer!!! just for MSN'ing).
Yes you can have MSN on the N80 there are half a dozen apps, but not the free official three one as yet (as far as I know), thats one complaint I have about three - "we're working hard on launching more handsets" isn't quite the impression I get ...
I've installed the official version on my n80 but it's not the one offered by 3, it's one i found on a site that i suspect is a little bit dodgy (it has lots of s60v3 software for free that probably shouldn't be free). do a bit of searching and you'll find the site! and yep, it works fine just like the pc version, same annoying noises and all!
