how i move the messeges to mmc?
10 replies · 2,722 views · Started 15 December 2002
because i keep almost every sms they take me up a lot of memory so i want to move them on the mmc when i choose mesege storage and tne mmc and then move it says to me tha now the server closes ant then nothinh happens so how i do it?
I cant quite understand what you are saying its quite easy to goto messaging, then Tools down to Message Storage... select, then press up to highlight the Communicator tab, press right then down to highlight Memory in use and press left to change it form Communicator to Memory card "" then hit done and its moved
a friend of mine managed to do this but is very dificult 😞it wants to much time and whne i try to do this a lost about 100 sms and didnt made it to move them
Open 9210=>Messaggi
menu=> Tools=>Message Storage
[Or simpler Messaggi--Shift+Ctrl+X]
Now the Message Storage window appear.
You have Communicator and Memmory showned there. Use the navigation keys and go to Memory.
Go to Memory in use and select change from the keys, and then move.
It might take a while, but not as mutch..
Good Luck.
Or as suggested here, on this forum, find another 92xx device and move them using InfraRed
