Transfering files to E62
3 replies · 2,121 views · Started 13 December 2006
I'm new to this whole thing. So please be patient? I can't seem to tranfer any files to my phone from my pc. When it looks like I have it finished, i then can't find them on the phone. I've been trying the PC Suite file manager. Any help would be appreciated. Thanks
Where, exactly on the phone do you transfer them? Have you expanded "Nokia Phone Browser" (the PC Suite file manager) to show the phone, its internal memory and memory card & and selected/highlighted an actual folder where you have copied things.
What app did you use to try to find the files on the phone?
What kind of files were they?
I did use the file manager in PC Suite. I opened the phone memory(c😊, data, then Docs. Last time I tried this, it did show that the file was tranferred. However, the Docs folder in the actual phone browser wouldn't show it.
I have only tried the .pdf thus far.
note: when I open the "file manager," I cant see any actual files. The phone does have some music and photos on it, but the file manager isn't showing them at all (that i can see?) Everything else does seem to sync just fine though(calendar and contacts)
how are you trying to browse for the files? if it is a pdf fo you have the pdf viewer from Nokias site installed?
