Inserting contact in N73 text format
4 replies · 2,828 views · Started 14 December 2006
Can someone help! I just bought Nokia N73 and in process of sending text message I found out that under 'insert' in options only templete is available, no contact of phone nos. . Does that mean one can not insert Contact from here? It is cumbersome going thru copy and paste all the time. Is there any software that can hep solve this problem?
Inno
I think I don�t understand well the problem. Because on N73 send an SMS is like on any other Symbian phone! What�s the problem:con?
nj7 wrote:I think I don�t understand well the problem. Because on N73 send an SMS is like on any other Symbian phone! What�s the problem:con?
Thank for your reply. The phone sends sms quite well but you can not insert contact directly from option's menu. You have to copy and paste. It is only templete you have there. Are you familar with nokia? This's a stanadrd.
Cheers
Innocent wrote:Thank for your reply. The phone sends sms quite well but you can not insert contact directly from option's menu. You have to copy and paste. It is only templete you have there. Are you familar with nokia? This's a stanadrd.
Cheers
If you want to insert a contact into the recipient field, just place the cursor in there, press the joystick and select from the list. If you want to insert contact details into the text field you will either have to copy & paste or manually type them in. I don't recall there having been any other way on previous S60 devices.
If you are looking to send someone's contact details to someone, simply choose Send from the contact menu and send a business card using one of the 5 methods offered.
I'm hoping I have understood your problem correctly.
Thank lovesign,
I thought there was a software or a method I could use to add a shortcut to 'Contact, into the insert menu, in addition to template icon. I hate to copy and paste considering that the keypad is just to tiny for me.
