Date-problem with the 7650!
5 replies · 1,458 views · Started 16 December 2002
the date on my phone suddenly changes after a couple of days.
it turns itself back to 2000, i change it back to 2002. and after a couple of days, when i look at the date again. it�s back to 2000..
what�s wrong? how can i make the date stay right??
kim, thanks
hi
do you connect your 7650 to your computer via infra ?
if so maybe the computer clock is set to 2000 and that is why the 7650 update its clock
I don't think so... if you select AUTO UPDATE, the phone will sync with the ISP machine time and update the phone.
I don't think it'll update from Laptop or PC machine.
[quote="didos"]hi
if so maybe the computer clock is set to 2000 and that is why the 7650 update its clock[/quote]
If you connect with PC suite via infrared it syncs the 7650 with PC clock.
It reads in the manual. RTFM 😃
