Help!! - PC Suite
2 replies · 1,729 views · Started 15 December 2006
I connected my phone yesterday to my pc and it asked me if i wanted to update PC suite as there was a new version.
I did this and then i found my phone wouldn't synch with the pc.
i then decided to uninstall PC suite and try an re-install it. Now i'm having even more problems.
When it is first the install it brings up the connection wizard.
When i click next, it brings up a window saying "There is no available connection type and therefore connection to phone cannot be established. The wizard will exit"
When i click ok. it then brings another window up saying "Failed to detect available connection types! Please re-install Nokia PC Suite"
I then go into the install bit of nokia pc suite and click repair, but it still does the same.
I've tried re-installing it a few times. i've even re-installed the version i got on the cd with my phone and still no good.
Any help will be very much appreciated.
Try uninstalling everything nokia off your system. Then download Nokia PC Suite cleaner from Nokia web site & run it in "clean System" mode. Then reinstall PC Suite & this should work.
Hope this helps
