this one will be PERFECT for unwanted calls and as alarm tone with your World Clock Pro. the wav is short but the looping is pefect. check it out! 8)
EDITED SIREN WAV!
Could you try to find the sound of the siren which warns for air raids?
Like in all WW2 movies there is this alarm when enemy aircrafts are spotted.
That'd be perfect.
The siren you posted here was quite nice too 😊
[quote="Makkara"]Could you try to find the sound of the siren which warns for air raids?
That'd be perfect.
The siren you posted here was quite nice too 😊[/quote]
i'll see what i can do. but in the meantime you can also search here. 8)
http://www.a1freesoundeffects.com/
[quote="seanmiguel"]this one will be PERFECT for unwanted calls and as alarm tone with your World Clock Pro. the wav is short but the looping is pefect. check it out! 8)[/quote]
nice wav cous. 😉
LOL!, nice one 😃
Well,its loud enough 😃
[quote="GhostDog"]Well,its loud enough 😃[/quote]
tell me about it!!! set an alarm this morning! forgot all about the wav and got freaked out by the sound!!!!! thought there might be fire or something! - well at least it got me up. that's a tough task you know. 😃 😃 😃
how do i place this siren wav as my alarm tone for worldclockpro?
[quote="Anonymous"]how do i place this siren wav as my alarm tone for worldclockpro?[/quote]
just go to the alarms view, set a new alarm and you will be prompted for the time, date, tone - as for that it will say that you're currently using default system - just select the siren.wav as tone and that's it. 😃
when i do that all i get is time, date, message, repeat.. im using world clock professional commercial version 1.10 .. is this it?tnx!
[quote="Anonymous"]when i do that all i get is time, date, message, repeat.. im using world clock professional commercial version 1.10 .. is this it?tnx![/quote]
wooops... sorry brah. i guess that is the problem. im running version 1.20. try checking out here http://www.psiloc.com/ and see if upgrade is free. when you have this version it should include the change tone option. 8)
i have v1.20 evaluation version... will this expire? tnx!
[quote="Anonymous"]i have v1.20 evaluation version... will this expire? tnx![/quote]
if its evaluation, yes it will expire. 8)
i have WorldCLOCK Pro 1.10 Full version..... anyone knows how to upgrade to 1.20 since the site says that updates are free for all paid users???????
[quote="mew"]i have WorldCLOCK Pro 1.10 Full version..... anyone knows how to upgrade to 1.20 since the site says that updates are free for all paid users???????[/quote]
if im not mistaken, all you have to do is download the trial version, send it to your phone via bluetooth or ir and the phone will prompt you to replace 1.10 with 1.20. ideally that should upgrade your version. just in case that isnt accurate, please keep hold of your key gen so you can re-install the 1.10 version if ever there will be problems.
hope this helps, if im mistaken, someone correct me please. and if that dont work, better email psiloc. 8)
i have tried ur method but wat i have gotton is the 1.21 evaluation version... ended up i reloaded my 1.1 version again....
i had tried to email psiloc but no reply from them....
any others can provide help???? :cry:
it seems that this sound dissapeared due to site known problem.
Can you re post it?
can someone send me siren.wav ? [email protected] ..tnx!
You have to be a registered user in order to see attachments, it only takes two minutes to register 😉
But unfortunatley, the attachments aren't working still, you gotta wait till they get online again, just register for the sake of future attachments!! (and of this friendly forum 😃)
[quote="mew"]i have tried ur method but wat i have gotton is the 1.21 evaluation version... ended up i reloaded my 1.1 version again....
any others can provide help???? :cry:[/quote]
just give ample time for the reply. i reckon those people are quite busy so it may take some time. 😊
here's the siren wav again. 😃
thanks
[quote="SnowMobile"]thanks[/quote]
special boy? hmmm, why the make over? :-? 😃 😃
Thanks smb....))))))
some siren sounds... I had more, but I reached the maximum size....
