I have installed keylock full ver but it doent effect
Problem with keylock
i have on my phone and it works well! what did you do??
[quote="duykhang"]I have installed keylock full ver but it doent effect[/quote]
Do you leave the application running in background?
i'm not sure about it but don't you need eprofiles to make it work! i don't know, cuz i have keylock and eprofiles as well, and if you explore through eprofiles you will see, that there is an option of autokeylock.
correct me if i'm wrong!
It does not need eprofiles. Just leave it running on background.
Start it and then press the menu key, and the app is left running.
ah ok!! was just a thought!
