Uppdate firmware to 4.37
9 replies · 2,031 views · Started 16 December 2002
Hi.
I have dl. the new firmware 4.37 (16mb) :-? Is it possible to uppdate the firmware by your selves? Amd if so, how do i do it?
Valhall
Welcome to the Forum Valhall
No. You can't - You will need an Flashbox for it. Not possible via Infra/BT
Yes. You Can. If you have the Flashbox.
PS: Pl look up the previous posts before posting. You are very likely to find an answer, which is anyday better than posting, and waiting for members to answer... afresh. And moreover, we have a splending "Search" tool at the top of everypage. Why not use it? Its free until further notice.
wht do u mean by 16 mb ? can u store 16 mb when we oonly store 4mb. you are jokin me. where did u get it from. mail it to me bro.
[quote="valhall69"]Hi.
Valhall[/quote]
PM a member by the username FOXHOUND, he might just be able to help you. he did the upgrade successfully by himself, and yes he basically did as sanjay said. 8)
[quote="simply258"]if u check with a file manager, the Z drive has 15mb .. 15.728 to be exact[/quote]
Z is ROM. files there are read only and you cant delete nor add anything there. 8)
