N80ie
2 replies · 1,813 views · Started 15 December 2006
ok so i flashed my n80 to n80ie, and im on the 3 network
So what does this mean for me now,
1. is the internet now free?
2. are the voip's free and also voip is voice over ip so surely i would need to connect to internet to use that,
3. can i get messenger
4. it still seems as slow as it used to be, is there a fix
5. is there a way to use the flash, so i can turn it on and off
6. talking about the flash, it defaults to off when im taking pics and i have to go into the menu each time to turn it on. How do i default the flash on for taking pics
i think thats about it lol
thanks in advance
halem111 wrote:ok so i flashed my n80 to n80ie, and im on the 3 network
The internet was free even before, if you connected to your neighbour's unsecured wireless network. As for Packet Data, you still have to pay for it. If you are on Three network, getting x-series silver will give you unlimited internet for �5 a month, if you can convince them that you are using an N73, otherwise they will say it's not working on your handset (which is b*****cks)
